Which amplifier: lab gruppen or cambridge 840A ?
Username: Oposky2006
U.S.A
Post Number: 15
Hello everybody !
I want to replace my NAD c315 with a lab gruppen iP900 or cambridge 840A V2.
I now the cambridge audio 840A..but not the lab gruppen... My dealer tells me about the iP900 which apparently has a very good sounding,dynamic,...The only drawback for me it's the fan noise...I don't know if it's audible.
So if you have any experiences with lab gruppen or if someone could advice me.
Thanks for your response
Username: Magfan
Post Number: 873
An amp with a fan will either be tiny/compact with no room to 'breathe' or in the case of lower powered stuff, Class 'A'. In either case, fans are generally noisy unless special low speed or specialty fans are used.
You need to check it out to see if it is distracting or runs too warm. If you have it enclosed, that may help with the noise, but cook it even faster.
my small dish / satellite receiver has a very tiny fan which you can hear during quiet passages in the sound track, later at night and when the fridge in the other room is off.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3663
I don't think I would want an audio component with a fan for serious music listening, unless it was dead silent.
Username: Artk
Albany, Oregon USA
Post Number: 12209
Even if it were dead silent to start with, I doubt it would stay that way.
Username: Dmitchell
Post Number: 3665
Especially if its a variable speed fan, like the one on a computer power supply. The hotter it gets, the louder it gets.
Username: Soundgame
Toronto, Ontario Canada
Post Number: 1120
Who's your dealer....sounds like they could be a pro-audio / DJ supply shop? That amp with the fan...that's commercial stuff. If you're attracted to the rugged stuff...take a look at Bryston...no fans, by-the-way.
Username: Artk
Albany, Oregon USA
Post Number: 12210
Lot of fans, just no mechanical ones...
Username: Magfan
Post Number: 874
goin' on 30 years ago I built a 4" box fan for the back of my Carver Cube. No matter WHAT I did to it, there was never any heat build up.
Of course, the fan was really loud, but that was ok, since the music was WAY louder! And I mean near redline for hours.
Username: Dmitchell
Post Number: 3672
Now we listen in a much more civilized manner, right Leo?
Username: Nuck
Post Number: 14614
Nuck moves the knob to 20 watts...
Username: Magfan
Post Number: 881
I don't know. Current amp goes to 120.
Yep, I'll admit it. Neighbors haven't complained in literally YEARS.
