There are speakers in the ceiling of my basement.. I haven't bothered with them until now and was wondering how i would go about connecting them to a TV. The wires that run to an outlet are just bare wires. What would i use to convert them to connect to a TV.. can u connect them straight to a TV?
I am sorry to say that you can not, and probably wouldn't want to if you could. Perhaps with a 5.1 Home Theater receiver the speakers would be useful as surrounds.
So buy a 5.1 Home Theater receiver and i can connect them to that... then the receiver goes to the TV? What do you use to connect the wire to it a banana plug? The speakers must be pretty old so i should probably replace them too. Where can you get cheap theaters and speakers?
