Sony receiver flashes "PROTECT"- what is wrong?
Raider
My sister has a Sony STR-DE335 receiver that is about 4 years old. When you turn it on, it works for about 5 seconds, then "PROTECT" flashes in the display and nothing on the receiver functions. The manual says the protective device on the receiver has been activated because of a short circuit. Has anyone had this problem? I opened the receiver up but found nothing physically burned or smoked. Any help would be appreciated before I tell her to send it for repair.
p2
one it is a sony! sony sucks!!! no seriously check and see if you have any speaker wires touching the back of the receiver or each other.
Raider
I have disconnected everything from the receiver. I get the message when I push the power button with nothing connected.
Username: Kegger
MICHIGAN
Post Number: 603
it does sound like you had a short at one time or another.
if you have disconected every single wire and it's
still doing it.
i would have 2 suggestions. after that i would call
sony.
try leaving the unit unpluged from power for at
least an hour then try it again because it may
have to reset itself. "with everything still disconected"
if that does not do it see if you can find a manual
reset either in the manual or through the onscreen
menu or try front and rear panels.
Raider
Thanks for the advice KEGGER.
Are you a Wolverine fan? I bleed maize & blue myself- GO BLUE!!!
I tried your suggestions but the problem still exists. I was able to perform a hard boot reset to the receiver but it still displays "PROTECT" within a few seconds after power up. Looks like it is off to sony next.
Thanks again.
