pleasee helppp Unregistered guest | Hello everyone i am very confused about this product http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-796 i want to use this to power 2 subwoofers in mi room. Is this possible and how do you connect the subwoofer to the amp do you just use speaker wire from the enclosure to somewhere on the amplifier? Also can a minisystem be your volume cotroll and where you play the cds from? Any help would be appreciated thanks alot |
Gold Member Username: Project6Post Number: 1003 Registered: Dec-03 | actually that amplifier is designed to fit in with a subwoofer enclosure. Instructions should be included with the product. It needs to be hooked up to the speakers from the inside. Signal is applied via receiver output. Depending of course on the design, you can also apply the speaker output signal from the receiver. |
pleasee helpp Unregistered guest | can you hookup a minisytem up to this amplifier easily? thanks |
Gold Member Username: Project6Post Number: 1007 Registered: Dec-03 | I haven't seen this particular model but at the minimum, it will have inputs for RCA line outs from any receiver. Some units will have speaker level inputs. So at the minimum, your mini system should have a line level output or RCA outputs. |
Bronze Member Username: NatediggidyBaltimore, Maryland U.S.A. Post Number: 37 Registered: May-04 | Yes, you can use this amp to drive subs with your mini-system. It has speaker level inputs and outputs so you would just hook it up in-line between your mini-system and your main speakers. It also has output leads that connect to your sub(s). What subs do you have? |
Bronze Member Username: NatediggidyBaltimore, Maryland U.S.A. Post Number: 38 Registered: May-04 | Yes, you can use this amp to drive subs with your mini-system. It has speaker level inputs and outputs so you would just hook it up in-line between your mini-system and your speakers. It also has output leads that connect to your sub(s). What subs do you have? |
