The 320Bee that I ordered will be in tomorrow, I overlooked the fact that currently I am driving a 2nd pair of outdoor speakers on my porch with my old Sony receiver. The Nad only has a place for 1 pr. of speakers. What would be some solutions to be able to play the porch speakers ? I only want to be able to play 1 pr. at a time. Thanks for everyones help.
Use banana plugs to connect the two pairs of speakers. Each time you want to select a different pair you will have to unplug one and reconnect the other. Using banana plugs makes this a simple matter, no bare wires to play with. If you want to do this differently, you could buy a speaker switch, very cheap. With this device you would plug both pairs into it and use a dial to select one or the other. I would prefer the former option as there is less degradation of sound, ie you aren't putting the signal through another device.
