New member Username: Keaneasc
San diego ,
Ca
Usa
Post Number: 1 Registered: Jan-10
Posted on My SONY C67ES CD Player (10y old and a great player) will not play in new music CDs. Those created by music co's in last 6m... A music CD version or format that prevents it? Or am I dreaming? |
Platinum Member Username: Nuck
Post Number: 14510 Registered: Dec-04
Posted on Do the cd's play in your puter to open properties and see what is there? |
San diego ,
Ca
Usa
Post Number: 2 Registered: Jan-10
Posted on Hi, Should of mentioned in the blog - they work fine on the Dell Desktop I did go back and retest - no on CD and worked fine on PC. Opened Properties - 10 .cda files only, nothing else. |
Post Number: 14511 Registered: Dec-04
Posted on gk, what if you rip a copy of a new cd and try that? |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 3608 Registered: Feb-07
Posted on Weird. Does it still play older discs? If you can see the .cda files, so should your CD player. |
San diego ,
Ca
Usa
Post Number: 3 Registered: Jan-10
Posted on Plays every old CD I have very nicely. I can see the .cda files on the new and old on CDs using the PC but the Sony CD player can not handle the new CDs. Will try to copy the new CD, create CD and try playing it tonight |
