Protect mode
Username: Hondadriver22
I got an audiobahn mono amp it was in use and the cables going into the + side of capacitor came out, i put them back and amp wont come out of protect mode. there are no blown fuses, what is the prob?
Username: Project6
Post Number: 944
try discharging the capacitor then try again.
Username: Soccer
Post Number: 220
If not, you problably have a protection thermistor blow (acts like a thermal fuse). If this is the case, leave it to a pro.
