Amp advice for Jamo
Username: Maguire245
Hello all, a nice forum you have here and I hope someone can help me.
I have a pair of Jamo Compact 1000 series and a pair of Jamo D265 A speakers.
I would like to know which is the best amplifier to power the D265 A's, because some people think a power amp should be used on them, but as we know that can ruin a hi-fi speaker.
Do I need to put in 200watts of hi-fi amp power, or will that just sound rediculous? Should I go for something 100watts or less?
Many thanks in advance, Harrison.
Username: Stu_pitt
Irvington, New York USA
Post Number: 3633
"...because some people think a power amp should be used on them, but as we know that can ruin a hi-fi speaker.
How so?
Some of the signals power amps produce can damage a hi-fi speaker if it's very sensative, it's better to have a A/V amp.
Username: My_rantz
Gold CoastAustralia
Post Number: 2866
Who told you that?
Username: Stu_pitt
Post Number: 3634
The only way you're really going to damage a speaker is if you drive the amp (seperate, integrated, or receiver's internal amp) beyond its abilities - clipping. Distortion kills speakers, very, very little else does.
There's no difference between 'A/V amps' and any other amp. There are different types of amps - class A, A/B, D, tube, and so on, but those aren't relevant to this discussion.
A seperate amp will probably give more honest power and control than a receiver's amp.
Username: Nuck
Post Number: 14467
Yep.
What scraggard is saying this is not so?
Wattage is rubbish. Speakers ain't got no watts.
The amplifier will deliver what you ask of it until it has no more to give.
But then, as an added bonus, some amps will give you the trash to take out.
If one cannot hear the difference, then one should go to best buy.
Some amps clip very hard, some very easily.
You really, REALLY need to know how your amp is reputed to clip. Or try it.
Username: Nmytree
Post Number: 402
HFM, I've never heard such a thing.
Seperates amplifiers typically deliver a higher quality current and are much better for driving speakers, compared to most mainstream or less expensive HT/Audio Receivers.
From what I have been taught, it's Recievers or amps that have poorly designed power supplies or cheap implimentation of power supplies; that are more likely to clip out due to a lack of quality current/power and fry your speakers.
