I have a passive sub hooked up to an old kenwood stereo integrated amp (KA-99) and it only sends out full range signals. I have assumed crossover or treble blocker as a solution but do not know how to choose or how to install...The driver is out of a JBL TLX PS10 sub if that helps...the amp is fried so i took out the driver...if someone know how to remove the crossover device out of the plate amp that would work too...also i need something after the signal has been sent out of the receiver because i have some jbl bookshelfs hooked up as well and i obviously want full signal from them
Yes, i have researched this but thats not a truly cheap fix...i got a treble blocker and if it doesn't work as good as i wood like then i will invest in a new amp
