Pre Reciver?
Username: Rickypearson
Post Number: 20
Can Some one Explaine what a Pre Reciver Does, and is it worth getting, thanks alot
Username: Kegger
MICHIGAN
Post Number: 514
do you mean preamp?
Post Number: 21
Yeah i sure did lol So whats a Pre Amp
Username: Kegger
MICHIGAN
Post Number: 521
a preamp with no amplifiers in it is what you
would connect like tape decks or dvd players and
such to then connect the amplifier to the preamp
outputs.
it is simular to a reciever and integrated amp
but has no amplifier built in. just an adjustable
signal that comes out the preamp outputs a very
low signal that goes up and down with the volume
control than that very low signal that comes out
the preamp outputs connects to an amp that increases
the output (amplify).
check out this thread it might help!
https://www.ecoustics.com/electronics/forum/home-audio/17643.html
J. Vigne
Kegger, move this over to definitons.
Username: Kegger
MICHIGAN
Post Number: 524
jan i have no problems with this being moved to
definitios.
but i'm not sure if you mean point this thread
their or the other link i gave.
or how you would like it done.
so you are more than welcome to do what you want
so as to get what you want.
i don't mean this as hey man you do it!
but i'm not sure what actually you are looking for
so move it how you like sir.
