Anonymous | Recommend me a system composed of serprate compnents and a receiver. I prefer Polk audio but if you find that something in this price range is better feel free to comment. Thanks |
swampcat Unregistered guest | If you already have some components such as cd, tape ect. Why not put your 1700 towards power amp and pre amp or pre amp tuner combo . Integrated amp maybe. If you already have a system buy speakers for 1700 and build around it as you go. What I'm trying to say is buy one peice at a time and get quality components and speakers rather than a system put toghether by a store chain. Polk has some very nice speakers! |
Stasis Unregistered guest | Well I just got a set of 2810s like everyone else, paid 300 for them. So does anyone actually know what these things are worth and are they truely not shieled? Email me at stasis@ptd.net |
Anonymous | If you've got room, try a Panasonic SAHE200K 6.1 receiver, Cerwin Vega E76C center front&rear, E715 fronts, and E710 rears. Price it out, it should get you going for under 1700, plus the fronts are so monsterous, you might not need a sub. You could back down and go with E710 fronts, E706 rears, and have enough left over for a sub. REX is a good source, sells all of these. |
