Just curious if anyone has heard or owns this subwoofer, it sounds via magazine reviews like it is a great subwoofer for both music and movies. It's not cheap but from the reviews, the price may be a steal compared to other reference hifi subwoofers. I would just like to hear from the avg. hifi enthusiast.
Very niiice. Have you tried the subs from SVS or HSU??
The DEF TECH subs are awesome. I have owned a PF-15 since 1997. It only has 185 watss, but a 15 inch driver. I can only put it up to level 4 before it is to overwhelming for my room. I recommend the PF-15PT (I belive that is the model #) which has a 15 inch woofer and 500 watts of power. It only runs for $699. The def. tech. sub is the single most improvement in my home theater. Try it you won't regret it.
An excellent sub is never overkill. Just adjust it to match your speakers. Proper set up is important. Bass should blend so that the sub is not noticable. Boominess and bloated bass can be obtained with the cheapest sub.
Besides you will not have to upgrade the sub if and when you upgrade your other speakers.
