New member Username: EmalvidoMexico, D.F. Mexico Post Number: 10 Registered: Mar-04 | At last got my toys, need to take the final step, a CD player. Margules Integrated Amplifier ACRH-1.2 B&W 602 speakers 4PR Kimber Kable biwired Im not looking for an expensive one, $400 top I was thinking on these ones. Denon DCM-380 Rotel RA-02 Denon Audiophile 1650 Any suggestion appreciated Ed P.S. For those who want to know more about the ACRH-1.2 http://www.margules.com.mx/index_magenta.htm |
Bronze Member Username: PalPune, Maharashtra India Post Number: 35 Registered: Apr-04 | Eduardo I have the same speakers as urs (602 S3 is it ?), same cable as urs...but yes my amp is Nad 320BEE, and the CD Player i am using is Nad 521BEE, which is i think one of the best CD Player in the entry level segment, and i think should be within your budget. |
Bronze Member Username: EmalvidoMexico, D.F. Mexico Post Number: 11 Registered: Mar-04 | Hello Finally got the NAD 521BEE, Im very happy with it, just bought it 1 month ago, need to break it in, superb player |
Bronze Member Username: PalPuneIndia Post Number: 47 Registered: Apr-04 | Eduardo Good to know that u like the CD player. Hope u have some great musical evenings..!!! All the best... Manish |
Unregistered guest | i had the thiel cs 1.2 and changed them cause of space. im planning on b&w 303 or magenta mini loudspeakers. any suggest?? |
Bronze Member Username: EmalvidoMexico, D.F. Mexico Post Number: 12 Registered: Mar-04 | What kind of music are you going to listen? Think the magenta Speaker If use my B&W's for all kinds of music, they are superb! As fo the Magenta, hmmmm dont know if they are a good choice for multiple music generes? |
Unregistered guest | Hola Eduardo, yo también tengo un ACRH1.2 y que bien suenan no? Donde puedo encontrar el CD NAD que mencionas? |
Bronze Member Username: EmalvidoMexico, D.F. Mexico Post Number: 13 Registered: Mar-04 | Bebbe Jaguar lo compre en Audioconcepts Houston TX saludos |
