I have a Denon 1803 receiver and I was looking for a speaker system. As I am not in USA, I do not have a lot of options here, so I almost decided to go for an AR HC 6 system. Is it a good match?
Hawk
Yes, I think that it is.
INSTALLGUY
THE DENON 1803 CAN RUN ANY SPEAKER SYSTEM WITH 12-6 OHM IMPEDANCE. I'VE DONE 4 OHM SYSTEMS BEFORE WITH NO PROBLEM. LOOK @ THE DB AT 1WATT/METER THE HIGHER THE BETTER IF YOU LIKE IT LOUD. ALSO WHEN YOU DESIDE TO PLAYBACK DVD-A OR SACD THE HIGH EFICENCY WILL HELP IN DISTORSION LEVEL AND STRAIN ON YOUR AMP. (YOU DONT HAVE TO BEAT ON IT THE GET IT TO ROCK). THE SPEAKER SYSTEM SHOULD BE MATCHED TO ROOM SIZE MORE THAN THE AMP. A 12X12 ROOM MAY BE OK WITH 5"WOOFERS AND AN 8"SUB,BUT A 15X15 ROOM MAY NEED 6'WOOFERS AND A 10"SUB .BUT DON'T BUY ANY THING UNLESS YOU CAN RETURN IT IF YOU ARE NOT SATISFIDE WITH SOUND. (SORRY SPELLING BAD)
Jorge
Thanks, folks. Now that I´ve heard the "YES" from Mr. Hawk, surely I will close the deal!
