New member Username: PonomousPost Number: 1 Registered: Dec-09 | Hey so my dad has no idea what he is doing and went and bought this without a receiver. It has been a long time since I have looked in to receivers. anyone know what a good mid range receiver would be for this system. Here is a link to the system and specs. http://www.vausaudio.com/va6000CS.html |
Gold Member Username: ChitownPost Number: 1457 Registered: Apr-05 | Good lord. Hope you have a big basement. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 14261 Registered: May-04 | . How much are you willing to spend on amplification? How loud do you want the system to play? |
New member Username: PonomousPost Number: 2 Registered: Dec-09 | no limit on spending i guess, if it goes over a certain limit ill just cover the rest as a Christmas gift. I would like to go the bi-amp direction but any suggestions are appreciated. yes the basement is big. ![]() |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 14262 Registered: May-04 | . Consider the top of the line Rotel or NAD. Both lines should have a power amplifier to pair with the receiver for bi-amping. . |
