Plese help with speaker decision!
Username: Blair387
hey everyone,
I have been doing tons and tons of research online for speakers and receivers, but can't decide on what to get. A lot of people tell me to go listen for myself and see what sounds good to me. But the problem is I don't have a big chain store near that carrys anything im interested in. And if they do, its their low end stuff, so I dunno if that would be a very good impression or not?
The first set I had my eye on was Infinity Primus speakers. I've heard many good things about them, but a lot of people say they are just "budget" speakers. Then I started looking at Klipsch Reference line. Very good speakers, but have heard complains about their "harsh" highs because of their horn tweeters.
So now im looking elsewhere. I hear lots of good things about Polk Audo Rti speakers? I'm also considering JBL L series, or Paradigm Monitor series. My budget is around $2000- $2500. But this will be spaced out over time. Im planning on getting a good 12" sub from SVS, as I hear they are really good.
So if anyone has any advice on setups in this price range with these three speaker companies, I would love to know.
I'm planning on getting a yamaha rx-v1900 or rx-v3900 "havent decided yet." So if any of these would sound better with the yamaha, please let me know. I will be using my set up primarily for movies, and games. Don't listen to music much. So if that helps at all, please give me some suggestions.
Thanks everyone.
Username: James_the_god
Lancaster, Lancashire England
Post Number: 825
Definately go to the trouble to find somewhere with more equipment. Especially since you have a pretty decent budget.
When I joined these forums i was like you "I have heard", "I have read" but really I hadn't really heard for myself for a long time until I did and realised it was the best way.
However, having said that I am a victim of buying and selling lots of stuff what to find out what I like simply through boredom and spair time. But audio shops and shows give a helpful insight.
Check KEF 3005 out for a surround system. This comes with a subwoofer which is pretty excellent when I heard it and the sound was very sparkly and dynamic. Whilst obviously the scale of the system isnt as big as larger hi-fi speakers, it'll fit you're preference for movies and games. Then spend the rest on the v1900 or an Onkyo nr807? You may even like Marantz sr7002! Dont just go with reviews!
On a final note dont forget some decent cable!
