What reciever for cerwin vega - XLS-215??
Username: Hakkers420
what kinda reciever would i need to run a couple of these?
http://www.cerwinvega.com/XLS215.php
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3312
Pretty much anything.
95.3 dB...
Username: Nuck
Post Number: 13984
You could power those with a potato.
Pick the best SOUNDING receiver, and ignore the power ratings.
There are some quite good stereo receivers available for nice prices.
Username: Exerciseguy
Fort Hamilton, NY United States
Post Number: 3092
I would consider an HK3490 or HK3390 from Harman's eBay store (a last minute $200 bid will usually do the trick for the 3490, even less for the 3390).
If budget isn't a concern, then the NAD 725BEE and Marantz SR4023 should also be on your short list.
