A solution for playing JVC camcorder(mod files) problems
Username: Quintuss
Los AngelesAmerica
[b]Question 1:[/b] "I recently purchased a JVC camcorder that records video as .MOD files. I can't seem to edit the files or play them on my PC. Is there a way to convert .MOD files to .MPG or something that works on my computer?"
[b]Question 2:[/b] I have a video file off my JVC as well and wonted to play it on WMP so i changed the file extension from .MOD to .MPEG. Now the problem i have is that the video quality is poor. It is like the video cant keep up with the playing speed, lines drag when something moves. I know this quality is poor because it plays fine on cyberlink power dvd. Any help plz on how to fix the poor quality????
[b]Question 3:[/b] I change the ext. mod to avi or mpg , and it works but the problem no sound at all.. .try to burn it into dvd, no luck, i try to burn it into vcd no luck also...
Full guide: http://www.yaodownload.com/forum/topic-2464.html}
Username: Geraldbj
Los AngelesAmerica
Happy holiday!
Username: Geraldbj
Los AngelesAmerica
Thanks, nice job!
Username: Geraldbj
Los AngelesAmerica
Thanks!
Username: Geraldbj
Los AngelesAmerica
Best of luck!
Username: Geraldbj
Los AngelesAmerica
Post Number: 7
Thanks, nice guide!
Username: Geraldbj
Los AngelesAmerica
Post Number: 8
Happy weekends!
Username: Geraldbj
Los AngelesAmerica
Post Number: 9
Best JVC video converter software!
Username: Geraldbj
Los AngelesAmerica
Post Number: 10
This can help me put JVC recorded video to my computer for further use.
Username: Geraldbj
Los AngelesAmerica
Post Number: 11
Really a good DVD rip software!
Username: Geraldbj
Los AngelesAmerica
Post Number: 12
Ok, I can transfer my JVC video to my iPod now!
Need to Register?
Forgot Password?
Enable HTML code in message
