Username: Exerciseguy Fort Hamilton,
NY
United States
Post Number: 3045 Registered: Oct-04
Monday, November 09, 2009 - 02:28 GMT http://www.unplggd.com/unplggd/product-review/product-realview-acoustic-research -av100b-tabletop-radio-with-ipod-docking-station-066058 ...I wonder if you can bypass the internal speakers and use it to fire-up some external ones?
Username: Jan_b_vigne Dallas,
TX
Post Number: 14168 Registered: May-04
Tuesday, November 10, 2009 - 00:05 GMT . Apparently not; http://audiovox2.info/docs/ar_hd/man/AV100B_DOC_OM.PDF Even if you could, there's a good chance the system eq is set to improve the existing speaker. With those specs I wonder what the tubes are doing in the circuitry, those two tubes could not be providing 10 watts of output even at 10% THD. .
NY
United States
Post Number: 3049 Registered: Oct-04
Tuesday, November 10, 2009 - 00:45 GMT They are only described as "audio power output vacuum tubes" , so your guess is as good as mine? If this sucker had an alarm, I'd jump all over it.
NY
United States
Post Number: 3050 Registered: Oct-04
Tuesday, November 10, 2009 - 01:33 GMT Jan, I thought you might appreciate Alex Scoble's remarks: http://friendfeed.com/crazy-gadgets/88fcf9e0/acoustic-research-av100b-tabletop-radio-with
TX
Post Number: 14170 Registered: May-04
Tuesday, November 10, 2009 - 16:02 GMT . Who? I only see and uninformed, bigoted idiot there. "If this sucker had an alarm, I'd jump all over it." That's what dogs and cats are for, CM, and they will jump all over you. .
