Username: Buzz23 WellingtonNz
Post Number: 1 Registered: Oct-09
Saturday, October 31, 2009 - 21:10 GMT my nad 3130 amp turns on but no sound comes out, if its not the fuses, what else could it be?
Username: Dmitchell Ottawa,
Ontario
Post Number: 3209 Registered: Feb-07
Saturday, October 31, 2009 - 23:07 GMT Does the protect light come on when you turn it on? Can you hear the relays click when you power it on? I had a really old, beat up 2150 that refused to turn on. I had it serviced for about 100 bucks and it worked perfectly.
Post Number: 2 Registered: Oct-09
Saturday, October 31, 2009 - 23:15 GMT yes the light comes on but no clicking sound. It was working fine and i moved my lounge around, reconnected the amp and speakers, it was going then all of a sudden no sound...im hoping its not a big job and hoping i can fix it myself.
Username: My_rantz Gold CoastAustralia
Post Number: 2599 Registered: Nov-05
Sunday, November 01, 2009 - 21:35 GMT Make sure there are no stray wires that could be shorting on your amps speaker connections.
Ontario
Post Number: 3211 Registered: Feb-07
Sunday, November 01, 2009 - 23:16 GMT That's a good idea. Check you speaker connections. If I recall the 3150 has the old spring-type terminals, maybe there's a short there?
Post Number: 3 Registered: Oct-09
Sunday, November 01, 2009 - 23:33 GMT ok thanks im going to check that now.
Ontario
Post Number: 3219 Registered: Feb-07
Tuesday, November 03, 2009 - 12:09 GMT Any luck Buster?
Post Number: 2602 Registered: Nov-05
Tuesday, November 03, 2009 - 22:40 GMT Uh oh Dave, Buster might have really found a short.
Post Number: 4 Registered: Oct-09
Tuesday, November 03, 2009 - 22:48 GMT haha i actually did find a short in the speaker connection. it's going just fine atm. Thanks alot for the help! APPRECIATE it.
Post Number: 5 Registered: Oct-09
Tuesday, November 03, 2009 - 22:50 GMT u saved me some good money mate. cheers
Post Number: 2603 Registered: Nov-05
Tuesday, November 03, 2009 - 23:06 GMT Glad your NAD is okay and you too, Buster. Happy listening.
Post Number: 6 Registered: Oct-09
Tuesday, November 03, 2009 - 23:08 GMT thanx M.R
Username: Nuck Post Number: 13852 Registered: Dec-04
Tuesday, November 03, 2009 - 23:17 GMT well done, MR.
Ontario
Post Number: 3225 Registered: Feb-07
Wednesday, November 04, 2009 - 12:19 GMT Good call M.R.
