New member Username: TomakaliChennai, Tamilnadu India Post Number: 1 Registered: Oct-09 | someone guide me how to setup 7.1 speaker systems in our church with 20metres length and 20metres width Hall |
Platinum Member Username: NuckPost Number: 13789 Registered: Dec-04 | I must assume that there is a movie night at the church? Is this your standard lovely church with wooden pews and lots of glass? |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3182 Registered: Feb-07 | Be fun to listen to music in a room like that. |
Gold Member Username: PetergalbraithCanada Post Number: 2234 Registered: Feb-04 | Permanent installation? Or something that gets moved in and out? |
Gold Member Username: My_rantzGold CoastAustralia Post Number: 2568 Registered: Nov-05 | Yes, is it for surround movies, surround music or . . . . . . surround sermons? ![]() Try Googling 7.1 speaker set up? Might be a good first move. |
New member Username: SpeakerluvChatsworth, Ca USA BABY!! Post Number: 3 Registered: Oct-07 | I am just guessing since, tomaklai is in India, I doubt it is a standard church with wooden pews... however, 20mx20m is basically a square room and an easy set up. If we had additional information it would be helpful, and how much you already know..if you are asking a basic configuration; 7.1 are designed to have a Front Right & Left, Rear Right & Left , and at the center of the distance between the front and back speaker an additional pair of speakers (midway). The center channel should go upfront above or below the screen and the subwoofer can go anywhere - what ever sounds best (non-directional sound). This is a very general break down, but with out more information... check out this helpful forum for 5 things you should know about surround sound. http://audiohotspot.blogspot.com/ |
Platinum Member Username: NuckPost Number: 13813 Registered: Dec-04 | Klipch. Maybe Klipchorns. |
