Amp suggestions
Username: Bdogg
Hi I was hoping some of you could help me find an amp for a home theater. I need something with 2 channels in the 200 watts per channel or higher range and 4 ohms. I don't know alot about home theaters or amps in general so I would love some ideas/recommendations. Also if you could recommend a surround sound preamp/processor I would be so thankful.
Thanks,
Brooke
Username: Nuck
Post Number: 13771
Brooke, are you running a 2.1 HT?
If not, how will you power the center channel?
What speakers do you have now?
What size is your HT room?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3179
Why a 2 channel amp for HT?
How about a multichannel setup?
http://outlawaudio.com/products/990.html
http://outlawaudio.com/products/7500.html
Username: Mike3
Wylie, Tx USA
Post Number: 2182
Budget?
Will you be mostly listening to music or movies?
Username: Nuck
Post Number: 13778
We sure need more info
