Silver Member Username: HawkbillyNova Scotia Canada Post Number: 713 Registered: Jul-07 | All of my audio gear is still plugged into one of those $0.77 power outlets so I thought I'd give one of these a try. http://www.a4audio.com/cd-detail.asp?CatalogID=844&Group=Accessories&SGroup=FIM It just arrived today so I'll install it tomorrow after work and see if it makes much of a difference. Never did make much sense to me to plug $200 power chord into a $0.77 outlet, but that's what I'm currently doing. |
Silver Member Username: MagfanUSA Post Number: 570 Registered: Oct-07 | Some would argue that a 200$ powercord, into a 100$ outlet into 10$ worth of Romex to the box is 'gilding the lily'. I kind of went a different direction, having a dedicated 20amp drop for amp and sub only. The remainder is thru a power conditioner and the low current stuff THERE is thru an isolation transformer which is part of the 'conditioner. I've got a couple ceramic outlets out the garage which I've never worked up the energy to install. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3532 Registered: May-05 | The electrician was at my house yesterday installing dedicated lines for the new washer and dryer. I had an interesting conversation with him about it. He said he charges about $150 or so to install a 20 amp dedicated line with dedicated ground. The price depends on how long the lines is, time spent, etc, but $150 is about average. He's done a bunch of them for stereos, and says they make a pretty good difference every time. He said he never really thought about it until he did the first one, then ran one for his stereo and another one for his TV. He claims its probably the best thing he's done for his system. If I owned the house, I'd have him run a line for the stereo. Its a very cheap thing to do, relatively speaking. I've never heard anyone who's done it say it wasn't a very good upgrade. If anyone's spending $100 on an outlet, a dedicated line for a few bucks more is a no-brainer, IMO. |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 714 Registered: Jul-07 | True enough Stu, but I already have a dedicated line to the box behind my rack. So that's already taken care of. |
Gold Member Username: Mike3Wylie, Tx USA Post Number: 2180 Registered: May-06 | I went the same route, 3 dedicated circuits with a second grounding rod outside,completely isolated from the house current. I used hospital grade outlets for about $12 each. One 20 amp quad circuit for my amps, one 15 amp quad circuit for my sources, and one 15 amp duplex circuit for my pre-amp. I have plugged a PS Audio Noise Harvester into each circuit. It only cost me about $225. After the first circuit you only really pay for the materials. From an audio performance perspective, it was one of the best if not the best return on investment I have achieved, not counting "free" tweaks. |
Platinum Member Username: NuckPost Number: 13759 Registered: Dec-04 | And the lights no longer dim to the beat of the music... I pulled 8 circuits while I was at it, but if you saw my little house, you would have done so too. |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 716 Registered: Jul-07 | I just have the one 20 amp circuit, but for my little 15W amp, I think I'm fine. My listening room is the only finished room in the basement, so I can easily run another circuit off of the breaker if I need to. One brother is an electrician and the other is an electrical engineer who works for the local power utility, so I get lots of advice and help on these sorts of things. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3534 Registered: May-05 | I didn't realize you had a dedicated line. If you've got the line, the outlet makes sense. If you don't, its probably a waste of money. |
Silver Member Username: MagfanUSA Post Number: 572 Registered: Oct-07 | I, too, think it was money well spent. At the same time, an outlet was put in the front eve to supply switched power for Christmas Lights. Money well spent, all 'round. And ... to Nuck ... No More lights flickering in time with the music, as was the case in the past, especially with the OLD Carver Cube. |
Platinum Member Username: NuckPost Number: 13764 Registered: Dec-04 | The dimming lights should be a dead giveaway to issues. Your power amp(s) like good steady power, indeed. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3176 Registered: Feb-07 | My next house I'm going to make sure I have a dedicated line for my gear. Right now the only dedicated circuit I have in the house is for my reef aquarium, with ground fault on the outlet. Probably a good thing, since water and electricity (I've read) make for not so much a good combination. |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 717 Registered: Jul-07 | LOL David. I'd love to have a reef aquarium. We have a freshwater one and we love it. Very peaceful to look at after a busy day at work. |
Platinum Member Username: NuckPost Number: 13770 Registered: Dec-04 | David, how do you de-humidify the room? Mike, I do not recall if the electrician installed a seperate ground for you as we discussed back then? |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3177 Registered: Feb-07 | I don't Nuck. I probably should. It's actually good in the winter since it keeps the dryness out of the house. It would certainly help in the summer. What size is your aquarium Chris? |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 718 Registered: Jul-07 | 40 gal David. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3178 Registered: Feb-07 | Cool. Mine is a 47 tall. It's kinda a weird dimension, but we chose specifically to fit an otherwise waste of space on my main floor. ![]() |
Platinum Member Username: NuckPost Number: 13773 Registered: Dec-04 | Is this tank subject to fungal bloom? I had a discus tank before, a 100 gal, which was a PITA. And get your lazyass off the couch, Dave and paint the bathroom. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3535 Registered: May-05 | I miss my Piranha tank. 6 Red Bellied Piranha in a 55 gal. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3180 Registered: Feb-07 | Reef tanks are susceptible to all sorts of algae and bacterial blooms. Usually in the early stages of the tank. Discus are notoriously hard fish to keep. And a 100 gals too Nuck. You don't do anything halfway. The bathroom is finished! |
Platinum Member Username: NuckPost Number: 13775 Registered: Dec-04 | Aquariums are wonderful therapy, until something goes wrong, then it is fish 911, usually in the middle of dinner parties, New Years, etc. Filling pails, the tub, sinks, and fish in plastic bags. I do not miss the drama. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3181 Registered: Feb-07 | Ain't that the truth Nuck. My 15 gallon plant tank leaked in my dining room and destroyed my beautiful hardwood floor. |
Gold Member Username: Mike3Wylie, Tx USA Post Number: 2183 Registered: May-06 | Nuck, copper ground rod 10 ft deep, 12 ft down from the house ground. |
Platinum Member Username: NuckPost Number: 13777 Registered: Dec-04 | sweet, Mike. David, when things go wrong, they go wrong in a 45 gal heartbeat. |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 719 Registered: Jul-07 | After installing the outlet and having a couple of listening sessions, I think the investment was certainly worth it. Lower noise floor, better soundstage depth, and a little more grunt in the lower frequencies. There is also a lengthening of decay times in delicate passages. Not night-and-day differences like some of the reviews I had read, but worthy improvements. |
Platinum Member Username: NuckPost Number: 13786 Registered: Dec-04 | And the power will never be in question again, Chris. That is worth the price of admission alone. |
