Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3144 Registered: Feb-07 | Just for fun today I switched my MCD-301 back to RCA cables. I've been running a set of XLR's that Nuck gave me for the past few months, and thanks to dual CD outputs on my Mac CDP I was able to quickly switch back and forth between the 2 types of cables. I think I actually enjoy the sound of the RCA cables just a bit better. The XLR's very clear and precise, with absolutely zero noise floor, but the RCA's inject just a little bit more liveliness into the listening experience. A bit more 'analog' sounding, if that makes any sense. Anyone else experienced this? |
Platinum Member Username: NuckPost Number: 13707 Registered: Dec-04 | I wondered if you would ever try, David. Order up a pair of balanced connections from Blue Jeans to compare...cheap man. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3145 Registered: Feb-07 | Finally got around to it Nuck, as you've noticed it takes me awhile to get to things. Not a huge difference, but noticeable. |
Silver Member Username: MagfanUSA Post Number: 549 Registered: Oct-07 | I'm using Mogami cables from Guitar Center. About the same $$ as BlueJeans, but no shipping lag. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3147 Registered: Feb-07 | The RCA's I'm using are BJ cables. I've found it takes about a week and half for them to arrive here in Canada the few times I've ordered them. |
Platinum Member Username: NuckPost Number: 13710 Registered: Dec-04 | Second the Mogami cables as well. music store stuff. |
Silver Member Username: MagfanUSA Post Number: 550 Registered: Oct-07 | Clarification: Balanced cables are Mogami All others are BJ / Belden including an HDMI which should arrive in a couple days. Anybody ever read the exchange between BJ and Monster? I wouldn't buy Monster anything based on this exchange. The BJ reply is one of the best legal letters EVER. True Classic. |
Silver Member Username: JawPost Number: 269 Registered: Mar-06 | Appologies if already posted, pretty old article: http://www.stereophile.com/features/335/index.html This guy agrees with you, DM. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3151 Registered: Feb-07 | Interesting article JAW. |
Platinum Member Username: NuckPost Number: 13714 Registered: Dec-04 | The article seems rather full of contradictions. The conclusions, with con's being limited cabling, is curious. The connection works more on design than implementation, IMO, and the cables matter less than proper usage. Also listed is cost., Further down is listed cost of single ended connections to do better. The noise floor and signal gain are apparant, and complexity and device choice increase signal strength through the chain. I believe that this compensates for alternate signal paths and circuitry. |
