What is your opinion of Energy RC-10 speakers?
Username: Unreal_t
United States
Post Number: 87
I'm on a budget and would like to upgrade my Logitech Z-5500 speakers. What do you think of the Energy speakers? Also what good price subwoofer and receiver would you recommend for this setup? Id like a 5.1 receiver so if i want to upgrade to 5.1 later on i can.
Thanks
Username: Nuck
Post Number: 13476
Tommy, cn you see me?
sorry, just had to.
You might be better served by deciding what you want more, music or movies.
A decently seup stereo can get close to center channel dialogue, but placement is critical.
Username: Nuck
Post Number: 13477
Energy have some pretty good HT packages.
The Take series has been around for a long time, but have seen some prety good competition for a long time.
Older series Energy, like the 22 series were very good as well.
Username: Artk
Albany, Oregon USA
Post Number: 10696
The RC-10 is a very good all around speaker and has received a number of good write ups. For the right price it's a hard one to beat.
Username: Unreal_t
United States
Post Number: 88
Great, i'm not looking to spend alot and i can get them brand new for $250.00.
Username: Nuck
Post Number: 13480
Take them.
Username: Soundgame
Toronto, Ontario Canada
Post Number: 1011
Energy builds some great subs that would work well with the RC-10. You might want to souce out an Energy sub to match....can beat the synergy.
Username: Unreal_t
United States
Post Number: 89
This is the setup i just bought.
Energy RC-10 (Rosenut) - Pair
Yamaha RX-V559 Receiver
Sony Saw3000 Subwoofer
12 Gauge Wire
Remember i am upgrading from a lousy Logitech Z-5500 HTS. Also this new setup is for my computer (with a high end sound card) not TV, i don't have an HD TV (and not planning on getting one anytime in the future).
Username: Nuck
Post Number: 13487
You could regurgitate a better sub than Sony markets.
Username: Unreal_t
United States
Post Number: 90
my room is extremely small, i looked everywhere and didnt want to spend $200 or $300 on a subwoofer and this one sounded better than the polk so i decided this one. for only $120 it was a good choice. im not an audiphile just someone that wants an upgrade from z-5500.
Username: Nuck
Post Number: 13488
Just so's you know, Tommy.
Username: Nuck
Post Number: 13491
http://www.canuckaudiomart.com/details/142307-energy_surround_speakers_4_c501_cc 50subwoofernew/
Username: Unreal_t
United States
Post Number: 91
My room is small (10x8). I got a 6.1 receiver because i might upgrade in future but now all i need is a good 2.1. Thanks though for the recommendation.
