Username: Piyush_gaur Post Number: 2 Registered: Sep-09
Thursday, September 03, 2009 - 06:41 GMT hi just want to know why 8 ohms speakers are use din Mobiles phones and not 4 ohms or 16 ohms speaker. i understand 4 ohms will draw more current and hence are not used. in that case why 16 ohms are not used as they will draw less current than 8 ohms. regards Piyush
Username: Jan_b_vigne Dallas,
TX
Post Number: 13886 Registered: May-04
Thursday, September 03, 2009 - 14:01 GMT . There will be less power produced into a 16 Ohm load.
Username: Nuck Post Number: 13342 Registered: Dec-04
Friday, September 04, 2009 - 01:42 GMT See, the phones are getting so small, that 16 won't fit. It is 8 for now, but they are on rations. Whiz kids are working on just one really small one even as we speak. Her name is Milli.
Username: Piyush_gaur Post Number: 3 Registered: Sep-09
Friday, September 04, 2009 - 07:55 GMT hi Jane / Nuck thanks for the information then just wondering why dont we use the 4 ohms one. is it just because it will take more current !! and for heat transfer as more current will go in. are these correct reasons ? thank you very much REgards PIyush
Username: James_the_god Lancaster,
Lancashire
England
Post Number: 812 Registered: Jan-05
Friday, September 04, 2009 - 11:57 GMT Nice to meet you Jane!
TX
Post Number: 13887 Registered: May-04
Friday, September 04, 2009 - 13:01 GMT . There is limited current storage in the battery. Use less currrent and the battery lasts longer. I doubt heat has anything to do with a mobile phone's speaker choice since ic's don't produce much heat. .
Username: Nuck Post Number: 13345 Registered: Dec-04
Friday, September 04, 2009 - 13:30 GMT Plus the need for speakerphone and the volume required for that function.
Username: Piyush_gaur Post Number: 4 Registered: Sep-09
Tuesday, September 08, 2009 - 12:23 GMT ok Guys !! i understand now - thank you very much
