Play guitar through speakers?
Username: Boxfactory
i want to play guitar through my speakers but im not sure how to. i have my 1/4th to 1/8th, a sound card, and a line in... ok hold on, lemme rephrase...
i can record my guitar through mixcraft fine but i want to be able to plug my guitar into my computer and have the notes outputting through speakers...
mixcraft wont output to my speakers(logitech'szcinema) for some reason so i need some other program. audacity works well playing back reccording stuff already but i want to hear myself play.
is there any amp software than i can just input guitar sound to and have it output to speakers immediately?
Username: Nuck
Post Number: 13230
guitar amp.
We need some help from the players here who have that little battery powered amp that was discussed.
Username: My_rantz
Australia
Post Number: 2419
Get a Vox Amplug. Plugs straight into your guitar. There's a choice of three. I have the AC30. There is an aux output as well as headphones. It has volume , gain and tone controls.
And they sound good.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13855
Why do you want to do this? You can't afford a cheap amp? For $20-40 you can have an amplifier. So there must be some other reason you want to play your guitar through crumby computer speakers that won't sound good with guitar anyway and won't withstand heavy metal power chords.
So what are you trying to accomplish?
well, i have a guitar amp, but i want to play through my computer so one, i can hear what im playing while recording, and two, so i can have a sound modifier so its like buying pedals without the buying part. :]
Dallas, TX
Post Number: 13856
As far as hearing what you are playing/recording any line out on your amplifier will accomplish that.
Otherwise, this is the Home Audio section of the forum. Try the Computer section or head to your local guitar shop or a good search engine for effects software.
