Kenwood VR6070 won't save settings
Username: Draddy
Hey guys, I just bought a used old kenwood receiver, and it's working fantastic.
Except, whenever I change a setting (such as the +/- volume on each speaker or the EQ settings) once you change inputs, or turn the receiver off, it defaults.
so after I get everything the way I like it, and turn it off, everything resets.
Any tips? is there a temporary memory battery that I don't know about (like in old desktop computers)?
Username: Nuck
Post Number: 13224
At some point, items that were designed to be disposable become just that.
Username: Edison
Glendale, CA US
Post Number: 900
You can leave it on all the time - some audiophiles leave their gears on all the time, because they sound better this way - it will cost you a little on electric bill, but this is an option.
Username: Altpensacola
You have to change the settings on the unit, not the} remote for them to save.
Remote settings are for temp adjustments.
that is not a "disposable" unit. Mine has been pushing great sound for over 5 years now.
You can actually find the manual for it on the Kenwood support site.
David, also check the archives on this site for some great info on this receiver.
In fact that is how I found this site.
https://www.ecoustics.com/electronics/forum/home-audio/1512.html
Username: Magfan
Post Number: 678
Is there an on-board battery?
A small watch-type cell will act just like this.
Replace the battery for 2$ and you're good to go.
BE CAREFUL digging into the unit. There are some hi-voltage areas which will render you room temperature. UNPLUG it and let it sit for an hour, 1st.
Wouldn't be surprised that the owner sold it for just the problem you are having and might be able to fix for pennies.
Username: Draddy
I really appreciate all the tips guys,
I actually don't own a remote, all I have is the front of the unit.
I'll check to see if it has an on-board battery, I assumed not since it's a receiver, but it's worth checking.
Username: Nuck
Post Number: 14050
Room temperature. hehehe
Username: Magfan
Post Number: 679
It is a computerized receiver. Same thing applies to your computer, when you change settings in the BIOS.
