I'm setting up a new system in my truck. so far I have 4g power and ground wire and my speaker wires have been ran. My speakers I have are a pair of Lanzar Max 12's (new from friend) 4 ohms 1000watts max. And I'm now looking for my amp.
My friends have 2 amps for sale, a Pyramid PB449X and a Kenwood KAC-8104D. I'm not sure about how the power ratings work and I know kenwoods are better. but the pyramid is in my price range. If i could get more, would the kenwood be alot louder than the pyrmaid?
Here is what I found on the details
Kenwood KAC-8104D Class D Mono Power Amplifier
Maximum Power Output: 1000W RMS Power Output (14.4V ): 300W x 1 at 4ohms (20-200Hz 0.5%THD) 500W x 1 at 2ohms (100Hz 0.8% THD) Built-in Variable Low-pass Filter: 50-200Hz (24dB/oct) Built-in Infrasonic Filter: 15/25Hz (18dB/oct) Bass Boost (0-18 dB at 40 Hz ) Class D Amplifier Circuit Aluminum Die Cast Heat Sink Power MOS-FET Switching Power Supply Speaker Level Input Signal Sensing Turn-On 2 Ohm Load Capability Line Output Terminals (RCA) for Extension Blue Illumination Gold Plated Power and Speaker Terminal Dimensions (W x H x D): 11-1/16" x 2-3/8" x 9-7/8" (280mm x 59mm x 238mm)
Two Channel Bridgeable Amplification 2x500 Watts/1x1000 Watts Output Bridged @ 4 Ohms Variable Gain Control/Remote Turn On/Off MOSEFT Pulse Modulation Power Supply 2 Ohm Stereo Stable Built-in Bass and Treble Control Gold Plated RCA Low Level Inputs Hi-Level Low Impedance MOLEX Input Speaker Output Terminal Strip S/N Ratio: Greater Than 90dB THD Less Than 0.04% Frequency Response: 15-30k Hz Overload/Thermal/Short Circuit Protection Power On LED Indicator LED Diagnostic Condition Indicator Automotive Type Fuse Protection Dimensions: 15.25''W x 2.25''H x 10.67''D
