New member Username: JosephinePost Number: 7 Registered: Feb-08 | I like the shape of this speakerstand but the brand was not mentiones. Does anybody know which one this is? Bye J. |
Platinum Member Username: NuckPost Number: 13155 Registered: Dec-04 | nope, but those are Totem Model 1 speakers, so you might look at Totem. The stans are not mass-loadable, and I would only rec them for light speakers with solid cabinets, much as the speakers displayed are. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 2913 Registered: Feb-07 | The stands look rather flimsy. I wouldn't use them to mount Totems, that's for sure. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3426 Registered: May-05 | They're Audio Physic Step monitors - http://www.audiophysic.de/step/index_e.html No idea what the stands are. Audio Physic makes their own, and don't look like those. Wierd. I have similar looking stands, which are a bit more substantial - http://www.apollohifi.co.uk/Speaker/Speaker.html I use Apollo A3 stands. They're inexpensive ($100 US), very sturdy, and can be mass filled. Not a single complaint from me. I didn't realize they were a UK company. Whatever you buy, make sure they're the right height. The speaker's tweeter should be at about ear level when you're seated. |
Platinum Member Username: ArtkAlbany, Oregon USA Post Number: 10511 Registered: Feb-05 | I knew they didin't look like Totem's. Good find Stu. |
Platinum Member Username: NuckPost Number: 13162 Registered: Dec-04 | Thanks Stu. Ignore previous posts, 'cept the ones that looked sober. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 3431 Registered: May-05 | I remembered the pic from when I was researching Audio Physic speakers. I couldn't remember which one they were though. AP's stands use glass at the bases and 3 silver aluminum fillable tubes. I have no idea why they wouldn't use their own stands in their pics. http://www.audiophysic.de/accessoires/index_e.html |
