Gold Member Username: ExerciseguyBrooklyn, NY United States Post Number: 2805 Registered: Oct-04 | http://www.enjoythemusic.com/magazine/equipment/0809/tekton_design_ob45.htm |
Platinum Member Username: ArtkAlbany, Oregon USA Post Number: 10472 Registered: Feb-05 | Very cool. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 2891 Registered: Feb-07 | Those are crazy looking! |
Gold Member Username: ExerciseguyBrooklyn, NY United States Post Number: 2806 Registered: Oct-04 | One slight problem might be the accumulation of dust on the up-facing rear driver, nothing some compressed air can't fix, a dust cover might be in order. |
Platinum Member Username: NuckPost Number: 13106 Registered: Dec-04 | And be cautious of the top-mounted posts. Although the Krell duo system that I saw and heard last week had a similar bass cabinet layout, I had to think about the consequences of storing conductive items such as beer cans on the bass unit. Not that beer cans or dust ever happen to a batchelor's place... Thanks for the post, CM. |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 637 Registered: Jul-07 | Thanks Chris. I've been watching for that for a while. |
Silver Member Username: SoundgameToronto, Ontario Canada Post Number: 901 Registered: Jun-08 | They are beauties. I actually haven't heard a full range speaker - other than so-called one's in my car. I'd love to hear a good single driver application on day but I'm skeptical about a single drivers ability to satisfy my preference for a detailed and crisp top-end. |
Platinum Member Username: NuckPost Number: 13119 Registered: Dec-04 | George, you will never, ever be satisfied with a frsd speaker, but you will hear magic trying to find it. The simple little Ling's that I still have are very nice simple speakers that still can surprise me. Tim put a tweeter in these as well, i bet THOSE would wake you up with 3 watts SET. Open baffles is where it's at for frsd. |
