Denon 1909/1910 or Pioneer VSX01/1019AHK
Username: Tech_freak
NC
Post Number: 10
Can't decide which one I should get.I can get a good deal on the 1909,but the 1910 has the Achor Bay processing.The VSX01 says it only does hdmi passthrough and the 1019 seems to be getting alot of good reviews.So,whichever you guys suggest I get,then that's the one I'm getting.I'll give you my tv specs and the equipment I plan on hooking up and you go from there.
Supported TV Formats
1080i, 720p, 720i, 480p, 480i
Native Panel Resolution: 1366 x 768
I will be getting a 1080p tv in the near future.
HDDVR-hdmi or componnet if handshake issues.
Bluray-Hdmi
Xbox 360-Component(old version xbox)
Hope you guys can help me out,I'm getting a headache.
Thanks
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2871
Pioneer.
Username: Nuck
Post Number: 13086
Are you connecting speakers?
cd player?
Username: Nickelbut10
Post Number: 2674
Just my opinion here, but to my ears the Pioneer AVR's sound better than the Denon products. That to me, would be reason enough to buy the Pioneer as features to me are meaningless compared to the sound of the product.
Just to throw a curve ball, in this price range, I would be looking at the new Onkyo line.
