The first thing I did for my home audio was run speaker wire through the attic. Come to find out my receiver does not have a speaker wire out for the sub. Is there a way to connect RCA's to speaker wire. Another possible problem is the receiver only has 1 out for the sub, I'm assuming this must be the left side? But the sub has input's for R and L. Will this be a problem? Thanks for any help
JH, your sub may accept high(speaker level) input, in which case you are fine. A 'Y' splitter is usually employed to take your LFE output from a single end at the receiver to the stereo input on the sub.
Nuck, I understand what your saying, and that may be my only choice. What I want to avoid is getting back into my attic (in florida). I already have all the speaker wire run and would like to utilize this if possible.
I am gonna be in FLA week after next, and while that helps neither your sub-connection, nor your present ventilation of the facilities, I can imagine that the attic is not a great space for a campout.
