Onkyo TX-SR506 Shuts down
Username: Cj2004
This receiver is less than 2 years old and has rarely been used. After taking my entertainment system down and changed out some devices the receiver now powers off shortly after turned on.
I've taken the following steps:
1)unhooked everything from the receiver
2)reset the receiver back to factory specs
3)taken steps (found in the troubleshooting section of the manual) to deal with amp protectin circuite if it was activated.
4)used different electrical outlets for receiver and preipherals
As soon as I push play on the cd player the receiver cuts off. If I unplug the cd player and try to attache speakers, the sytem cuts off
Nothing has worked so far. Any suggestions?.
Username: Nuck
Post Number: 12874
CJ, that seems to be seperate problemms, one with input, and another with ouput.
You need to find some speaker connection that will let the thing play, which should not be difficult.
I suggest you double check the polarity and integrity of your speaker wiring to start.
Username: Nuck
Post Number: 12875
Check that the tape input is not selectd, do not use phono input for anything but a table, and run the receiver is stereo to start, try just one speaker, if need be.
Username: Frank_abela
Berkshire UK
Post Number: 3679
If nothing is attached to the receiver, does it come on, and if so, does it stay on for more than 5 minutes (give it time to warm up)? If not, there's something wrong with the unit.
If it stays on, then switch it off and attach just one channel of your CD player. Switch on, set the 506 to another input which is not the CD player and hit play on the CD player. Does the 506 stay on? If so, switch over to the CD player. Does it switch off? If so, it's likely the output circuit which is at fault.
Either way, it's most likely going to have to be repaired by Onkyo...
Username: Julian437
ok
