Bronze Member Username: PbdrPost Number: 99 Registered: Apr-05 | I'm looking for a good pair of speakers to use with my home system for my deck. So outdoor speakers definitely, but I'm also wondering if it's possible to get decent wireless speakers for outdoor use as well. So recommendations on 1) wireless outdoor speakers and 2) outdoor speakers in general. Preferably <$500 for both categories. Thanks. |
Platinum Member Username: NuckPost Number: 12744 Registered: Dec-04 | Check out Cambrige, as well as Advent(made by somebody else). |
Gold Member Username: Nickelbut10Post Number: 2612 Registered: Jun-07 | Here is three different types Paradigm make. Just to throw out another idea. Their Rock speakers are neat. http://www.paradigm.com/en/paradigm/speaker-type-outdoor-marine.paradigm |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 11722 Registered: Jun-04 | Actually ive had the smaller advent speakers and I wouldnt recommend them for this project. They are made by Jensen by the way. |
Platinum Member Username: NuckPost Number: 12764 Registered: Dec-04 | remember that we are dealing with 2 different types here as well. Outdoor speakers are fine, wireless are amplified speakers, sooo... Boston makes some wireless speakers as well, and they do small speakers pretty well. |
Gold Member Username: GavdawgAlbany, New York Post Number: 1276 Registered: Nov-06 | Klipsch makes a bunch of different outdoor speakers, an outdoor subwoofer, and a "rock" speaker. http://www.klipsch.com/na-en/products/outdoor-speaker/ |
