Unhappy with system, time for a change?
Username: James_the_god
Lancaster, Lancashire England
Post Number: 748
Here's my scenario.
I've just come home from Uni and my set up sounds quite a bit different (upstairs instead of ground floor and with hollow walls instead of solid). At Uni I did find the treble a little prominent and the bass a bit thin but other positives of the setup up made up for it. I have an a&r cambridge a60 (arcam) with acoustic energy aegis neo 1s and this setup sure gets a lot of things right.
But right now, more than ever is how hissy and thin it sounds. Theres no bass impact or that midrange 'thickness' that wharfedale diamonds have with their kevlar drivers!
Do I need a subwoofer perhaps to balance it out and fill the lower octaves and midbands?
Or is my system generally a bad match. Please help me, its no longer musical!
Username: Hawkbilly
Nova Scotia Canada
Post Number: 601
Please describe your listening room. Dimensions, layout, flooring, furnishings, listening position, wall coverings, ceiling materials, speaker positioning, etc. Pictures are even better!
What sort of rack is your equipment in ? Are you using any acoustic isolation or dampening devices ?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2705
Interesting that changing rooms can make the system sound so dramatically different. I'm guessing the room you have your system in now is bigger than your previous room at university?
Username: Dmitchell
Post Number: 2706
Obvious question, but have you tried moving the speakers around JJ?
Post Number: 749
Chris, heres the pictures..my room is a mess because I haven't unpacked properly yet, just handled the important stuff!
The amplifier is on top of the desk. Using Chord Din Interconnect and Classic Cables ( I love Chord).
I've just notched the bass up to half 1 on the amp and this seems to have done the trick to some extent. I honestly think I need a small sub which I can put underneath my desk.
Dave, I have done and before I had them completely parallel to the walls, as they are in the pictures seems to work better. As you can see, I have very little room to work with. Interestingly enough, my room at university was about twice the size!
Username: Dmitchell
Post Number: 2712
Thanks for the pics JJ. With the room furnished the way it is, it'll be difficult to get optimal speaker placement, that's for sure.
The left speaker is really close to the wall. Have you tried moving it out a bit?
Username: Dmitchell
Post Number: 2713
... oh yeah - clean your room!
lol.
Post Number: 750
Hahaha I knew that was coming!!
I haven't tried that, its just in all honesty it has to be like that or I wont be able to move around.
Here's a thought for you..
If i turn the volume right down and creep it back up I notice treble is very previlent on low volume. Only at a medium and louder volume does music become acceptable. If I turn the bass up to FULL!! then at low volume, music sounds more like it should.
Does that back up my theory for why I think a subwoofer would sort stuff?
Username: Artk
Albany, Oregon USA
Post Number: 10048
The room looks well dampened....
Username: Nuck
Post Number: 12718
The left speaker port displacement is bouncing off the wall and against a mirror.
Username: T_bomb25
Dayton, Ohio United States
Post Number: 2202
The doorway isnt doing him any favor either,I would try another way with no doorway or closet opening like where your bed is.Like Art said the room looks well dampened,and it doesent look to big for the Neo's to perform optimumly without a sub,just play around with different walls,you should be fine,or either your just ready to get new speakers.lol
Username: Nuck
Post Number: 12721
Clean up the space, be ready to move things around, then have sullied underwear as specific damping materials.
Username: Nuck
Post Number: 12722
I suggest guest p@nties on the headboard...
works for me.
Post Number: 751
I'm glad it passes the dampening test. I really wish I could have had the desk against the larger wall with speakers either side, but I couldnt convince the parents when we were decorating the room a few years back.
I suspected the doorway and mirror would be a culprit. My room is generally a poor setup then! New speakers I can only imagine would cost considerably more than what I can afford!
I'll live with the bass turned up a bit for now, I'm surprised how more balanced it sounds by just doing this.
I may try covering part of the miror!
Post Number: 752
Nuck, no way!!
Username: Nuck
Post Number: 12724
way
Username: Dmitchell
Post Number: 2717
P@nties work nicely as port bungs. Better than socks.
Username: Nuck
Post Number: 12726
let's just stop this here.
Username: Dmitchell
Post Number: 2718
ok. I'm done.
Username: Hawkbilly
Nova Scotia Canada
Post Number: 602
The room may be too well damped. I'm guessing that you have some very good (and accidental) bass traps....the box spring, mattress, and comforter especially. If sound balance is the issue, then you need to have less in the room that absorbs the frequency of sound that you're missing....in this case bass.
The lack of one frequency range can make the another frequency range seem overstated, when perhaps it isn't. You probably don't want to do this but if you could, try largely emptying the room, orient the speakers in some reasonable method, and then slowly add things back in and see what happens as you do. You may not be able to leave things that way, but you'll at least know how much of the issue is room, and how much is gear.
I think you'd get great sound out of your gear if you can get the room right.
Post Number: 753
Chris you've hit it right on the mark.
Last night it was so hot I couldnt sleep so I decided to tinker with things. Its not the bass that I needed more off, it was treble which I needed less off. I've toned the treble down by about 6db (according to graphs in my amplifier manual).
So from 1khz, there is a gentle roll off and this has improved the balance.
Bass isn't as I remember it but it's substantial now I've tinkered with the treble and music is more like it should be. I'm not sure why it works, but it does. I would guess its because my speakers are quite small/the tweeter is overkill for my small room?
I shall definately clean up the room within the next week (theres a lot of things to sort out) to see what difference this makes.
Unfortunately, theres not much I can do about these accidental bass traps I have.
Post Number: 754
O, the balance is also set to very far left! This creates a more stable image with how I've placed the speakers which are now parallel to the walls and 3 inch away from them.
Username: Hawkbilly
Nova Scotia Canada
Post Number: 605
Is your back right against the wall when you are in your listening position ? Are you in that back corner or on a sidewall ? Where would the primary reflection points be on either side of you ?
Sorry for all of the questions.
Post Number: 757
I listen from two areas, from that corner on the bed and from the chair when at my computer as background music not 'critical' so to speak, since I dont have any option.
I'm unsure how my room reflects, all I can tell you is that the speakers both face walls, parellel to backwalls, 5 inch gap since 3 inch was too boomy.
I'm not a fan of my room for setting up a system. That said, it still sounds brilliant!
End of September this year and a new room means desk placement!!
Username: Hawkbilly
Nova Scotia Canada
Post Number: 606
Thanks. Listening in a corner can focus reflected sound, as can listening too close to a back wall. Some of the treble glare or gain might be due to this. Just a thought. I'm glad you've got it sounding better.
