MartinLogan - Abyss - 12 " High Resolution Subwoofer
Username: Insearchofbass
Post Number: 11701
Thought this was a pretty good deal for someone so thought id share it.
http://www.audioadvisor.com/prodinfo.asp?number=MLABYSS
Username: Nuck
Post Number: 12678
Thats a prety big sealed sub, i can't coorelate the weight to other driver surface materials very well.
Which spec is going to direct me to fast response in a sealed sub?
Username: Jan_b_vigne
Dallas, TX
Post Number: 13680
Qts will somewhat tell you about "speed". But I doubt that's listed in an assembled subwoofer. And it's still how the driver aligns with the enclosure (the system Qts) that determines such a quality. If there is an impedance graph provided, look for one fairly large impedance peak at the system resonance of a sealed system (two peaks for a vented system). If any more than one peak is indicated for a sealed box the system has probably been underdamped. in the end you might have to use your ears and not look for a spec since "speed" is your perception more than a spec in the manufacturer's literature.
