hi people, i need some advice . i am going to purchase one of these receivers within the next day or so but do not know which one to get. the 790 is a 6.1 receiver and the de697 says its a 7 channel receiver. which one would you people recommend as i mean the 7 channel looks more advanced but i may be wrong. i want one that will last the longest in terms of surround formats. thanks
It's no competition here. The DB790 will easily blow away the DE697 in terms of sound quality, power and most features. It's a great receiver for a very low price.
Yes, probably, but that is so very uninteresting in receivers of this class. The DE-series has very low quality everything so I suggest you avoid them at all cost.
One very noticeable difference between these is their 'feel', the DB is metallic, has strong binding post for speakerwires and weigths 14,5kg (32lb), while the DE series have usually a very plastic feel, spring clips for speakers and they weight around 7-9kg (15-20lb). Also the DB790 has fine amps wich are not scared of higher current to 4ohm speakers, while the DE-series are even having problems driving more than two 8ohm speakers.
Nope. The 790 easily beats even the Yamaha 750 in sound quality and power and it's also more pleasant to use. I just got a new review with receivers of this class, and the Sony won the review and was the only one wich was almost equal with the reference device HK670 stereo amp.
