HK Avr 330 Speaker selection?
Username: Delirium
I just got a new avr 330 and I dont see any a/b speaker selection on it? Can anyone tell me if this receiver has this capability? Other receivers I have had in the past have always had this. Thanks.
Username: Rickypearson
Post Number: 22
Well If it Doesnt have it on the back then there no way to Do A/b Speaker Selection, Unless you run to your Local Electronics store and Buy a Small Box the Plugs in to you Main front Speaker Connection at the back and allows you to have a/b speaker slection
Username: Goose
Post Number: 88
What your AVR330 has is better than A/B switching. You can do multi-zone! Assuming, of course, that you only want 5.1 in the main zone, you can use the extra 2 channels of this 7.1 receiver for a second zone, with independent source and volume. Check your manual for details.
