New member Username: JodavisToronto, Ontario Canada Post Number: 2 Registered: Apr-09 | Hello, I'm building my own subwoofer for a basement I will be moving to. I don't have any idea on the right enclosure for home use. How do you get the right box for a sub? Here's my future sub: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-622 |
Bronze Member Username: Mike19Tallahassee, Fla USA Post Number: 20 Registered: Jan-09 | Hi julien. Please do not take this personally, but if you do not know what enclosure to use for that speaker, then maybe you do not have enough experience to build your own sub. Mike |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 2455 Registered: Feb-07 | There's plenty of info out there. http://www.diysubwoofers.org/ I think Julien is up to the task. |
Silver Member Username: MagfanUSA Post Number: 425 Registered: Oct-07 | DVC and 2 ohms each, at that? Boy, you need to talk to Andre about an Amp! And a power supply......hint hint.....to make it all happen. Beware structural damage when cranked up. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 13525 Registered: May-04 | . Parts Express will help you with the correct enclosure volume and port size. You would probably be wise to order one of their prefabricated enclosures and not mess with building a box yourself. Call their tech services department. . |
Silver Member Username: MagfanUSA Post Number: 426 Registered: Oct-07 | Madisound also sells a line of plate amps..... But, Jan, doesn't a pair of 2 ohm VCs raise an alarm? You could always wire them in series! |
Platinum Member Username: NuckPost Number: 12151 Registered: Dec-04 | Granted it looks like a killer, but how did you decide on this particular driver Julien? Have you shopped some higher end subs already? |
Silver Member Username: MagfanUSA Post Number: 428 Registered: Oct-07 | Nuck....I looked up this driver and it is pretty pricey....so much so that he could get a HSU VTF3. I think we have another Andre here, and he wants realistic jet plane takeoffs, right in his own living room. Too much is never enough, I say......... |
Platinum Member Username: NuckPost Number: 12156 Registered: Dec-04 | I might be tempted to go with pro amps for this job! Maybe Crown amps on each coil... |
Platinum Member Username: NuckPost Number: 12157 Registered: Dec-04 | Nothing says excess like overdoing it! |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2954 Registered: Dec-06 | ... |
