I recently purchased some towers that are unshielded. My center is shielded and will go on top of the TV, but I am not sure exactly how far to position the towers to make them safe. I need to know the minimum distance because the layout of the room doesnt allow me to spread them out very much. The amp is pushing 75wpc, if that matters. Also, should I assume a powered sub is unshielded?? Thanks for all the help.
The distance required depends on the size of the magnets in the speaker and the type of TV. Any interference will be noticable as colour distortion.
A distance of about two to three feet is usually sufficient.
A powered sub may be shielded, but most are not, so to be safe, assume it isn't.
I had to return my unshielded speakers for shielded versions due to TV interference so I understand your concern.
I hope this has helped.
TC
J. Vigne
If you are not using a CRT (tube type) television you need not worry about distance. Rear projection, plasma and LCD TV's are not affected by the magnetic force of the speaker.
I have only seen rear projection sets with guns mounted at the bottom so unless you are going to put your speakers underneath the TV you shouldn't have to worry.
