New member Username: BhaskarPost Number: 1 Registered: Mar-09 | I need advice on what amp to pair with my Dali Lektor 2 speakers (http://dali-speakers.com/display_content.php/INT/speakers.html/189/1426) quick specs of these lektors: Sensitivity (2,83 V/1 m) [dB]: 85,0 Nominal impedance [ohms]: 6 Maximum SPL [dB]: 106 Recommended amplifier power [W]: 25 - 100 I will be using them for music and movies (40%/60%) through the RCA out from an Asus Xonar Essence PCIe card. I currently use Sennheiser cans for all music and movies and it sounds really nice, so I want something that will sound pretty decent (with movies) without burning a hole in my pocket. I plan to spend around £400 for the amp. Cheers! |
New member Username: Mike19Tallahassee, Fla USA Post Number: 1 Registered: Jan-09 | Hi Bhaskar. I would welcome you to this Forum, but this is my first post here too. I'm not sure I understand what you want. Are you going to do stereo or multi-channel? If multi-channel, 5.1 or 7.1? Are you looking for amplification only or an audio/video reciever (processor + amplifiers)? If an avr, do you want it to be able to decode Dolby True HD and DTS Master HD? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 13469 Registered: May-04 | . If you have the opportunity, try any of the excellent Lirpa integrated amplifiers. ![]() . |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 2385 Registered: Feb-07 | That seems pretty obscure Jan. What the heck is a Lirpa? |
