New member Username: RobouserPost Number: 1 Registered: Mar-09 | Hello everyone. I just purchased a Boss VT-1 and need to connect it to my PC MIC IN connection. It will look like this. Mic -> VT-1 -> PC I need to know which cable I need to get to connect from the VT-1 MIC OUT connection to the computer MIC IN. The connections on the VT-1 look like this: Also, the manual for the VT-1 is located here: http://uploads.shrike.us/BossVT-1manual.pdf Also, are there any adapters that would allow a standard PC microphone (non-USB) to connect to the VT-1 INPUT connection? Thanks for the help and links are much appreciated. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 2312 Registered: Feb-07 | What does this thing do? You'll more than likely need some sort of adapter to connect this to your mic on your soundcard. |
New member Username: RobouserPost Number: 2 Registered: Mar-09 | Thanks, I already found the adapters I needed. |
Platinum Member Username: NuckPost Number: 11861 Registered: Dec-04 | Another satisfied OP. Cheers MH |
