Trying to decide whether I should get paradigm Titans v5
Username: Werty10
Modesto, California United States
Right now I have a pioneer vsx d514 receiver hooked up to two infinity beta 20s as fronts and two infinity tss 1100 speakers as rears theres No sub or center. I have them hooked up to my computer via spdif through an auzentech X-plosion sound card. I was wandering if I upgraded to paradigm titan monitor v5 would there be a difference in sound? are the titans superior to the betas? I cant audition them because no one sells them locally im planning to order them online. Please any advice would be good
Username: Artk
Albany, Oregon USA
Post Number: 9075
The Titans are one of the worst speakers Paradigm makes and with the Monitor series that's an accomplishment.
Username: Werty10
So your saying the monitors are better which bookshelf speaker would you recommend for under $400?
Username: Nuck
Post Number: 11691
https://www.ecoustics.com/electronics/forum/home-audio/548514.html
Username: Exerciseguy
Brooklyn, NY United States
Post Number: 2422
Glad you did that Nuck and not me.
Username: Artk
Albany, Oregon USA
Post Number: 9076
The Wharfedale Diamond 9.1 is certainly a wonderful speaker. So far I like it better than the Beta 20. They can be had very inexpensively from STO Sound & Vision. Keep in my that I find the Beta 20 to be an excellent buy and better balanced than the Titan Monitor (then again almost everything is).
Username: Werty10
Do the wharfdales have less equal or more base than the beta 20s. They seem smaller and weigh less and the woofer is a 5 opposed to my beta 6 1/2. What does it do better than the betas? Thank you guys for answering my other questions.
Username: Artk
Albany, Oregon USA
Post Number: 9080
Read the Stereophile review...It's pretty spot on from my perspective.
http://www.stereophile.com/standloudspeakers/1105wharfedale/
Username: Werty10
Sounds like it has an excellent tweeter and has got some good base. One question though do the highs ever sound harsh or piercing? I was looking at the wharfdale 9.2s is it the same as the 9.1 except with bigger drivers or is it different?
Username: Artk
Albany, Oregon USA
Post Number: 9083
Tweeter is exactly the same, and it has a bigger woofer and lower bass response...might just be the ticket for you. And no the highs are not at all bright.
Username: Mike3
Wylie, Tx USA
Post Number: 1805
"harsh or piercing" is subjective and system dependent to an extent.
What you have upstream of your speakers has a lot to do with how they sound.
You speaker set up and your room itself have a lot to do with how they sound.
Everybody hears things differently.
