PLEASE can some1 work my problem out ;)? Ports or not and speaker impedance
Username: Codfish6688
Hi was wondering if anyone can help me i have eight 4ohm speakers in which i want to install into two boxes to run the system in stereo so i will have four 4ohm speakers in each box. I need to know wheather i need a port in the box and weather to run them at 4ohms or 16 off a 2x200 at 8ohms amp. I am using clarion SRP1620M components which run 70w rms into a 6in speaker at 4ohms, please help?
links for amp and speakers follows
http://www.altronics.com.au/index.asp?area=item&id=A4156
http://www.clarion.com/au/en/products/2008/audio/speakers/premium/SRP1620M/au-en -product-sc_1172393311444.html
any inputs on speaker configuation would be very helpful.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13400
Contact the speaker manufacturer. We tend not to design speakers for people here. You might also try other forums such as "DIY".
Username: Nuck
Post Number: 11697
A speaker array is terrible difficult to pull off sucessfully, JG.
A diy speaker forum is a good start indeed.
