Bi-Wiring ?? If your speakers can handle it, should you use it ??
Jeff Corwin
If speakers can be Bi-Wired, is it worth the money to invest in bi-wired speaker wire? Or should the speakers just be connected regularly? Help from all of you out there is appreciated.
Thanks!
You don't need to buy special wire, just use two sets of wire instead of one.
Berny
Bi-wiring is "snake oil", makes you believe you're hearing better sound...lightens your wallet, adds weight to the bank accounts of manufacturers. Now if you are one of those that use expensive biwiring hardware just because it looks cool and you like it, then more power to ya! I know I would if i can afford it...i'd get pure gold connectors just because I can if i could...but in the belief that it will improve the sound and that electrons will flow better through a bi-wired speaker, nah! Save your money, buy more and better equipment, upgrade, etc!!! Save enough so you can actually bi-amp if you want...much more beneficial! peace
Jeff Corwin
Thanks for your help guys! I will save myself a couple of hundred bucks.
