CAD-805C Mono Block
Username: Ggregt01
AthensGreece
Hi to all.
Has anyone the specs on the IS-805 interstage iron and also the CT-805 output.
Thanks
Username: Jazzman71
Phoenix, AZ USA
Post Number: 545
Have you contacted Cary?
Username: Ggregt01
AthensGreece
No I have't.
Would they give that info out though?
Username: Soundgame
Richmond Hill Toronto, Ontario Canada
Post Number: 641
Doesn't hurt to try and if nothing shows on Google, going to the source might be a good start.
Username: Jazzman71
Phoenix, AZ USA
Post Number: 554
Cary's customer service has been very helpful to me. If you are trying to determine if components are in spec, they might help you out. The worse that can happen is they say no.
