Speaker rec
Username: Oldhorsehide
I recently hooked up my old Technics turntable to a Marantz 1060 amp to transfer my old vinyl onto my home computer. Very tired of listening to the music using my computer speakers, would like to purchase speakers, new/used, appropriate for my audio setup. I used to have a decent stereo setup.........which ended up with the ex wife.
What speakers would be appropriate for a 50 year old guy; my ears have suffered through industrial noise, firearms, guitars, etc.?
Username: Nuck
Post Number: 11616
Welcome JP.
What kind of investment are you willing to make, and how much space are you wishing to fill with Metallica type music?
Funds are limited, $200-300, daughter in private college. Space is 14 ft by 25 ft but I live in the country....music is fairly loud.....electric blues, classic rock(Stevie Ray Vaughn), classical once in awhile. My son is a Metallica guy. Want speakers that will work with modern equipment when I upgrade.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2124
Is the budget you mentioned for speakers alone?
I really like my Paradigm Atom version 5. They cost me $260 a couple of years ago and sound great, plus they're easy to drive.
You could also look on the used market as well, if you're not adverse to that.
Username: Artk
Albany, Oregon USA
Post Number: 8974
I would recommend the Infinity Primus 362's. Sizeable floorstanders that are nearly full range. They can rock out and don't require a mammoth amp to drive. They are just a hair above the budget but punch way above that.
Username: Exerciseguy
Brooklyn, NY United States
Post Number: 2382
I second the P362,
http://www.theaudiovideosource.com/InfinityPrimus.html
...but a pair of Beta 20s is still the best deal going need I remind everyone.
http://search.stores.ebay.com/Harman-Audio_Beta-20_W0QQfciZ15QQfclZ3QQfsnZHarman Q20AudioQQfsooZ1QQfsopZ1QQfsubZ10225969QQsaselZ26519532QQsofpZ0
A $50 bid will most usually win you one of these gems.
