Base response from Bose 901's
Username: Burnt0013
North Arlington, NJ USA
Hi Guys!
I have a Carver 4000 Pre Amp, Carver PM 350 Power Amp, NAD 521 Bee, Nakamichi OMS2, Carver TDR-1550, Teac H300, a Philips 212, and Bose 901 series 2 speakers. I like this system and am going to have to live with it for a while. Could someone tell me how to improve base response?
Username: Jan_b_vigne
Dallas, TX
Post Number: 13349
Turn up the Bose equalizer.
Username: Edison
Glendale, CA US
Post Number: 885
Bose 901s don't have much bass.
I would get better speakers if I were you, since the rest of the system is pretty good - the speakers are holding you back.
Hope this helps...
Username: Jazzman71
Phoenix, AZ USA
Post Number: 546
What he said, and check the speaker placement and room treatment. Bose 901s are sensitive to this since the low end is reflected. Mine worked best suspended from the ceiling.
Username: 007b
Post Number: 55
Great party speakers (as long as you don't give a sh*t about accuracy). If properly equalized bass is adequate but will generally not shake the foundation.
