New member Username: CblossomPost Number: 1 Registered: Jan-09 | I'm new to the whole audiophile world, and I purchased a Scott 299 tube amp and would like to get speakers that would compliment it. Any suggestions? I typically listen to classical, jazz, and rock music. Thanks!!! |
Platinum Member Username: NuckPost Number: 11484 Registered: Dec-04 | Welcome Cb. Have a look here, this will require some reading and reearch on your part to make the most of it. http://diytube.com/phpBB2/viewtopic.php?t=1342 http://www.canuckaudiomart.com/details/112369-almarro_k303a_tube_friendly_speake rs/ http://www.coincidentspeaker.com/opinions.htm |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 13318 Registered: May-04 | . https://www.ecoustics.com/electronics/forum/home-audio/546673.html |
Silver Member Username: EdisonGlendale, CA US Post Number: 876 Registered: Dec-03 | Check out the reviews done by the pros here : http://whathifi.com/BestBuys/Hi-fi-speakers-BestBuys/Speakers/ When you are ready to buy, I would recommend getting them used here - www.audiogon.com You will end up with more quality this way - also if you don't like them, or when you want to upgrade, you can sell them there for about the same price. What source are you using? TRL modified Sony SCD-CE595 got great reviews - and it plays sacd which sound much better. http://6moons.com/audioreviews/trl/595.html Welcome to this exciting hobby Chris - just don't get the upgrade bug like many audiophiles - and buy it right from the start by doing research, and asking questions on sights like this one, or www.audiogon.com, or www.audioasylum.com I hope you reach sonic nirvanah you are looking for... |
